Technical Problems
Zak (netAirspace FAA) 11 Aug 13, 18:34Post
We appear to have a technical problem right now. Everything involving our photo database (including the homepage and forum threads with embedded photos) currently leads to timeouts.
We do not know the reason yet, but my guess is that this may be a hard disk failure. We are trying to get this resolved with our hoster asap. I will keep you posted about the progress, but worst case is that this can be resolved only on Monday.
I'm sorry for the inconvenience.
Zak (netAirspace FAA) 11 Aug 13, 18:51Post
Looks like the site is working properly again. I still don't know what went wrong, so for the time being, I'd make the usual recommendation to copy longer posts to the clipboard before submitting them, just in case the problem reappears.
JLAmber (netAirspace ATC & Founding Member) 11 Aug 13, 19:04Post
The last successful activity before the site went down appears to be this photo:
The site was taken aback by the pure awesomeness of the shot and needed a break, I shouldn't wonder :))
Zak (netAirspace FAA) 11 Aug 13, 19:06Post
Aksherly, the photo db went down, when I uploaded this shot:
Including the photo comment. So I blame the NSA. {mischief}
FlyingAce (netAirspace ATC & Founding Member) 11 Aug 13, 19:16Post
You both broke the site, then {grumpy}
ANCFlyer (netAirspace ATC & Founding Member) 11 Aug 13, 19:44Post
FlyingAce wrote:You both broke the site, then {grumpy}
{laugh} {laugh} {laugh} {laugh}
helvknight (Founding Member) 11 Aug 13, 21:17Post
I thought it was actually Ed's friend that had caused the problems
ShanwickOceanic (netAirspace FAA) 12 Aug 13, 06:20Post
I like this sort of problem. I slept right through it!
helvknight wrote:I thought it was actually Ed's friend that had caused the problems
It's sitting in its safe* corner looking unusually guilty, and I can't find where it pissed, so you may be right...
*it thinks - for now.... {mischief}
Zak (netAirspace FAA) 12 Aug 13, 10:34Post
Our hoster just got back to me. There was a DDOS attack on their network last night. The brief downtime was a result of their counter measures, that required certain services to be temporarily shut down.
The attack was not specifically targeted on netAirspace, so for the moment, all should be fine again.
