The essentials to car care
Airfoilsguy (Founding Member) 28 May 09, 20:39Post
Just got done cleaning the cars and bike. The bike may be on its way out but that is another story.
What do you use to keep them shinny?
This what I use and for what.
Rain-X >> Crystal clear driving in the rain
Liquid Glass >> protects the paint and keeps it shiny
Mothers metal polish >> Keeps the metal shiny
Black Magic >> shiny tires
Armor All >> protect the inside
Zymol >> For cleaning a car that others have neglected, then with the Liquid Glass
Mobile One >> makes for a happy engine
Bud Ice >> Helps lubricate the care cleaner
GQfluffy (Database Editor & Founding Member) 28 May 09, 20:56Post
I can't stand cars with that black crap on their tires...
AA61hvy 28 May 09, 23:23Post
I use just about everything you list minus Rain X.
Of course don't forget the shammy and California brush. Though nothing beats dropping the car off for a nice detail and picking it up later that day..... {bugeye}
"I'm at the wrong airport!"
-Ollie Williams
Queso (netAirspace ATC Tower Chief & Founding Member) 28 May 09, 23:55Post
ShyFlyer (Founding Member) 29 May 09, 00:35Post
Back when I wasn't lazy, I used this stuff called RejeX instead of wax. Far easier to apply, lasts a hell of a lot longer.
http://www.rejex.com/rejex.html
ORFflyer (Founding Member) 29 May 09, 12:18Post
Airfoilsguy wrote:Rain-X >> Crystal clear driving in the rain
{check} Best car care product ever invented.
AA61hvy wrote:I use just about everything you list minus Rain X.
See above. Try it, and you'll be damn glad you did during the next storm.
AA61hvy wrote:Though nothing beats dropping the car off for a nice detail and picking it up later that day.....
{check} {check} Agreed - and put the Rain-X on right after I get it home. {thumbsup} ;)
Mark 29 May 09, 13:13Post
I washed my truck three years ago. Waxed it seven years old. But, the interior is clean. That's what counts. I use Windex to clean everything. Screw the Armor All and related crap that makes your dashboard all slippery...makes it look fake and unnatural.
And the engine is pretty clean. No leaks. No spills.
Tornado82 02 Jun 09, 01:10Post
Queso... I love that Wax As You Dry stuff!
I'm not a big fan of Rain-X though.
I'm baaaaaaack.
Cadet57 02 Jun 09, 01:20Post
Mark 02 Jun 09, 01:28Post
Cadet57 wrote:
One of the worst filters you can buy. I used to bring my own Motorcraft FL-1A with me to the Quickee-Lube when I got my oil changed to make sure they don't put on their usual Fram garbage.
Cadet57 02 Jun 09, 01:32Post
Mark wrote:
Really? I've never used anything but that in all my cars. Sure beats $25 at the stealership.
Mark 02 Jun 09, 02:06Post
Cadet57 wrote:Really? I've never used anything but that in all my cars. Sure beats $25 at the stealership.
Read this and make your own decision.
http://people.msoe.edu/~yoderw/oilfilte ... study.html
Queso (netAirspace ATC Tower Chief & Founding Member) 02 Jun 09, 02:28Post
Mark is right, Cadet. Fram filters are bottom of the barrel. They've had some media failures which caused spot oil starvation in engines and their anti-drainback valves suck, which means your engine is running without lubrication for a short time after startup.
More education: http://home.mindspring.com/~ed_white/id7.html
Cadet57 02 Jun 09, 02:36Post
Queso wrote:Mark is right, Cadet. Fram filters are bottom of the barrel. They've had some media failures which caused spot oil starvation in engines and their anti-drainback valves suck, which means your engine is running without lubrication for a short time after startup.
Hm, wow... I wonder what the OEM equivalent to my filter is, $25 a pop isnt very appealing.
cornish (Certified Expert - Aviation Economics & Founding Member) 02 Jun 09, 08:35Post
What do I use to keep my car nice and shiny?
The local Kosovans :))
In my town they have a particularly good hand car washing and cleaning service - they're not expensive, and always do a really good job on mine (I give them a good tip and i'm a regular) inside and out.
I live in a flat, so washing the car myself is just more hassle than its worth...
Queso (netAirspace ATC Tower Chief & Founding Member) 02 Jun 09, 12:30Post
Cadet57 wrote:Hm, wow... I wonder what the OEM equivalent to my filter is, $25 a pop isnt very appealing.
Since you're driving an import, I'd be looking for a Denso or a Wix or maybe a Mobil 1. If you can't find them locally it might be worth buying a few at a time on teh interwebs. That's probably what I would be doing, anyway.
Mark 02 Jun 09, 14:44Post
You'd be amazed at the car parts available on eBay. The only part I've had to buy locally in the past five years are a set of spark plug wires because I wasn't sure of which of two different distributor end connections I needed. Go to the oil filter's web page, search to find the filter number needed for your car, then go to eBay.
Cadet57 02 Jun 09, 17:09Post
Mark wrote:You'd be amazed at the car parts available on eBay. The only part I've had to buy locally in the past five years are a set of spark plug wires because I wasn't sure of which of two different distributor end connections I needed. Go to the oil filter's web page, search to find the filter number needed for your car, then go to eBay.
Whenever i've needed parts, Autozone always had the oem equivalent, usually takes 1-2 business days, but its not a biggie. I did a quick google search, and I've found a few places that sell the filters, one place had them for $5.50 a pop, or a case of 10 for $57. But I've never heard of the place so im kind weary about buying there.
I've heard of wix, but im pretty sure they arent sold around here, Mobil1 I know I can get, and I do like their oil after all :))
Queso (netAirspace ATC Tower Chief & Founding Member) 02 Jun 09, 17:58Post
Cadet57 wrote:Mobil1 I know I can get, and I do like their oil after all :))
That's a whole other thread, we won't even get started on the pros and cons and rumors of Mobil1.
JLAmber (netAirspace ATC & Founding Member) 02 Jun 09, 19:16Post
cornish wrote:What do I use to keep my car nice and shiny?
We have a similar service operated by a group of highly enthusiastic Romanians. Those guys manage to get my rims shining far better than I ever could :))
MD11Engineer 03 Jun 09, 19:54Post
I'll doubt thatyou'll get "Wix" filters in Germany, at least not under this name. Nobody would buy a spare part called "wank" :)
Jan
Airfoilsguy (Founding Member) 03 Jun 09, 20:23Post
Jan
Same reason Nova's didn't do well in Mexico. ;)
