Since it has been relatively slow in the space world as of late notwithstanding the ECLSS issues on the ISS, I figured that a US rocket launch would be of some interest.
This will be the first launch of the
Atlas V rocket in the 531 configuration. That means that the rocket will fly with a 5-meter diameter payload fairing and three strap-on solid rocket boosters. The Atlas V has flown twice with three SRBs before, in the 431 configuration with a 4-meter diameter fairing. The payload for this flight will be the first AEHF satellite for the US Air Force. Launch from
SLC-41 at Cape Canaveral is planned for 11:07 UTC (7:07 EDT) on 14 August, and has a two hour launch window.
AEHF (Advanced Extremely High Frequency) is the successor/replacement to the
Milstar communication satellites which were launched by the
Titan IV between 1994 and 2003.
ULA press release wrote:The AEHF constellation of satellites will provide 10 times greater capacity and channel data rates six times higher than that of the existing Milstar II communications satellites.
There will be three AEHF satellites which will replace the entire Milstar constellation.
The rocket was rolled to the launch pad this morning:
Photo credit: Pat Corkery, United Launch Alliance
The launch will be webcasted by the United Launch Alliance on their website:
http://www.ulalaunch.comThere is also a mirror available if you cannot get the webcast to work (which begins 30 minutes before the planned opening of the launch window):
http://mfile.akamai.com/29730/live/reflector:58048.asx?bkup=58227Note: Wikipedia links embedded into the text for relevant articles.
