Probe Lands On Comet
Allstarflyer (Database Editor & Founding Member) 12 Nov 14, 18:26Post
Around a couple of hours ago
http://www.bbc.com/news/science-environment-30026398
The landing on Comet 67P/Churyumov-Gerasimenko was confirmed at about 1605 GMT.
The landing caps a 6.4 billion-kilometre journey that was begun a decade ago.
The lander sank about 4cm into the surface, suggesting a relatively soft surface.
They're still trying to figure if it's anchored properly, though. It also led Foxnews.com (and probably several other outlets).
AndesSMF (Founding Member) 12 Nov 14, 18:51Post
And this news excites me like there is no tomorrow. {cheerful}
Lucas (netAirspace ATC & Founding Member) 14 Nov 14, 17:02Post
And the battery is set to die in less than 24 hours. Oops.
FlyingAce (netAirspace ATC & Founding Member) 14 Nov 14, 17:37Post
Lucas wrote:And the battery is set to die in less than 24 hours. Oops.
Wasn't it solar rechargeable? I recall reading it was supposed to work intermittently...
AndesSMF (Founding Member) 14 Nov 14, 17:42Post
How do you land a probe that has the weight of a coin? Apparently it was a little tough to do. It 'bounced' a kilometer high, and when it finally came down it was in a location were there are only 1.5 hours of sunshine per day.
Recall that when the lander bounced, the comet was still rotating.
ShanwickOceanic (netAirspace FAA) 14 Nov 14, 17:46Post
FlyingAce wrote:Wasn't it solar rechargeable? I recall reading it was supposed to work intermittently...
Yep, but where it ended up it's getting something like 1.5hrs' light in every... 12? 24? hours, which isn't nearly enough.
I've been gripped by this story, it's absolutely intriguing. I hope they pull off a miracle.
bhmbaglock 15 Nov 14, 00:50Post
Issue is that where it finally landed after two bounces, it's next to a small cliff and shield from sunlight during most of the day. Also, the bounces seem to provide evidence that portions of the surface are much more, surprisingly so, solid/rock like than expected. Even if the life is greatly reduced as a result, this completely changes what we think about comets which is a phenomenal result in and of itself.
Lucas (netAirspace ATC & Founding Member) 15 Nov 14, 00:52Post
bhmbaglock wrote:Issue is that where it finally landed after two bounces, it's next to a small cliff and shield from sunlight during most of the day. Also, the bounces seem to provide evidence that portions of the surface are much more, surprisingly so, solid/rock like than expected. Even if the life is greatly reduced as a result, this completely changes what we think about comets which is a phenomenal result in and of itself.
The sheer size of the comet is pretty cool.
AndesSMF (Founding Member) 15 Nov 14, 00:59Post
bhmbaglock wrote: surface are much more, surprisingly so, solid/rock like than expected.
Which explains the bounce, instead of the dirty snow absorbing the landing, the harder rock bounced it right back. I wonder if the harpoons were designed more for a softer surface than solid rock.
