ISS Demo Paving The Way For Satellite Service
miamiair (netAirspace FAA) 01 Feb 13, 13:24Post
ISS Demo Paving The Way For Satellite Servicing
The big Canadian-built robot on the International Space Station has wrapped up a week of work aimed at demonstrating that its robotic cousins could one day handle the daunting task of servicing satellites in orbit, a capability that many hope will lead to commercial service stations in the sky. Riding on the station's robotic arm, which was also built in Canada, the special-purpose dexterous manipulator—universally dubbed Dextre—has been snipping wires, opening caps and pumping ethanol at an exterior testbed fitted with the kind of hardware a robotic satellite-servicer would find on a spacecraft in need of more fuel, a new flight computer or something else that would keep it generating profits for a few more years.
Known as the Robotic Refueling Mission (RRM), the washing-machine-size, $22.5 million experiment was the last payload removed from the last space shuttle mission. Astronauts Mike Fossum and Ron Garan stowed it on the station during the STS-135 flight of the shuttle Atlantis in July 2011 (see photo), and Dextre later installed it on an Express Logistics Carrier equipped with the power, data and commanding capabilities needed for the demonstrations (AW&ST July 4, 2011, p. 62). Its eponymous activity was due for completion last week, when Dextre was to screw a special tool into a stock satellite fill-and-drain valve it had opened by snipping wires, unscrewing caps and nuts and retaining them, and then begin pumping ethanol.
“[This will] demonstrate that we have a leak-tight seal made by a robot to a non-cooperative interface, which would be, I think, be a first, ever, for NASA, or any agency for that matter,” says Benjamin Reed, deputy project manager in the Satellite Servicing Capabilities Office at NASA's Goddard Space Flight Center, Md.
The schedule was set back a few hours as Dextre snipped lock wires on one of the access caps, when Canadian experts called a halt so they could investigate an intermittent software problem. The issue was resolved during a pre-planned day-long pause in the demonstration, and work resumed on Jan. 17. The Canadian team in St. Hubert, Quebec, was one of four groups involved in the telerobotic demonstration. ISS Mission Control Center-Houston commanded the robotic activity, while the ISS Payload Operations Center at Marshall Space Flight Center, Ala., operated the Express Logistics Rack. Reed's team coordinated the demonstration from its facility at Goddard.
The pumping tool designed to pass the ethanol—chosen because its handling characteristics are similar to the toxic hydrazine propellant most satellites use for station-keeping—is called the EVR nozzle tool, “EVR is 'extravehicular robotics,' as opposed to 'EVA,'” says Reed, who learned his trade developing astronaut tools and extravehicular activity procedures for the servicing missions to the Hubble Space Telescope.
