miamiair/forum/images/avatars/gallery/first/user54/1.pngoffline(netAirspace FAA) 05 Aug 10, 14:09
Above: Ta-152
In June 1942, a Luftwaffe deserter fortuitously presented the Allies with his Fw 190A fighter intact, the detailed examination of this remarkable product of the Focke-Wulf Flugzeugbau profoundly influenced fighter thinking in Britain. It directly result in the issue of specification F.2/43 to which was designed the Hawker Fury, embodying numerous features directly copied from the Fw 190A, and F.19/43 which produced the Folland Fo.118 fighter project, also owing much to the design of the Fw 190A. What higher tribute could have been paid to what was undoubtedly the finest warplane to which Germany gave birth.
The Focke-Wulf Fw 190 Ranks with the Supermarine Spitfire, Vought F4U Corsair and North American P-51 Mustang as one of the best fighters of World War II. The Focke-Wulf 190 was the work of a team of German designers headed by the famous Kurt Tank. It was evolved basically as a successor to the Messerschmitt Bf 109 fighter, although the official view was that it would never be capable of matching the operational prowess of the Bf 109. How wrong this proved!
Chief company designer Kurt Tank's Wurger (Butcher Bird) was Germany's most potent piston-powered World War II fighter When the Fw 190A entered combat in the summer of 1941. It immediately outclassed the Spitfire V, which appeared sluggish and outdated by comparison. From that time on, in spite of some severe problems with the BMW 801 engine, the 190 kept even or ahead of Allied fighters through successive versions.
The BMW 801 engine tended to overheat, but this fault was rectified by improvements to the cooling fan and, in general, the Fw 190A was highly praised by the test pilots. They particularly favored the wide-track undercarriage which tremendously improved ground stability as compared with the Bf 109. One of the unusual features of the fighter commented on by test pilots was the fact that, at high altitude and high speed, the BMW 801 engine produced a pair of contrails which started immediately behind the exhaust exits and completely hid the wings.
The Fw 190 prototype first flew on June 1,1939 and production deliveries began in late 1940. Within a year, Fw l90s were making low-level sweeps over southern England in daylight, against which the Spitfire Vs, then in service, achieved little success. The situation did not improve until the Royal Air Force received more powerful Spitfire IXs, in partnership with four-cannon Typhoons.
In the autumn of 1937 the Reichluftministerium placed an order with the Focke-Wulf Flugzeugbau for the design development of a new single-seat fighter to supplement the Messerschmitt Bf 109. A second "iron in the fire" as RLM officials referred to the order at the time. The contract was placed with Focke-Wulf primarily because this company was not extensively committed to the development of other combat aircraft and possessed a highly qualified design team headed by Dipl.Ing.Kurt Tank. Tank's design team prepared two proposals; one based upon the use of the Daimler-Benz DB601 liquid-cooled engine and the other upon the use of the BMW 801 air-cooled radial engine. At that time the radial engine was not favored as a fighter power plant owing to its drag and the restrictions that its bulk placed upon forward view during taking-off and landing, and, in consequence, General Ernst Udet's decision to proceed with the development of the radial-engined fighter came as a profound surprise to Tank and his colleagues.
The BMW 801 was a considerably heavier engine than its predecessor, although the overall dimensions differed little, and necessitated a stiffer engine mount and extensive structural strengthening. The re-design involved gave Blaser an opportunity to rectify one of the few faults that had manifested themselves in the first prototype. Test pilots had objected to proximity of the engine to the cockpit which resulted in extremely high cabin temperatures, sometimes reaching 55 degrees C. (131 degrees F.), which, as Sander said, felt as though he had his "feet in the fireplace." In addition, exhaust gases found their way into the cockpit and necessitated the continuous use of an oxygen mask. Therefore in the next prototypes the cockpit was relocated further aft, a move also suggested by the c.g. problems presented by the heavier engine.
Most of the Fw 190A-0s were sent to Rechlin Roggenthin for pre-service tests. During intensive flight testing it was discovered that the engine cowlings frequently flew off at high speeds, and internally stressed cowlings with stronger locks were requested. Some re-stressing was also proved necessary, and it was found that above 250 mph the cockpit canopy could not be released in an emergency. The latter problem was solved by fitting two standard 20 mm cartridges which blew the rear end of the canopy backward far enough to let the slipstream get under it and pull it away. Pilots also complained that there was a serious risk of hitting the tail assembly when baling out and requested the fitting of some form of ejector seat which would throw them clear. However, in view of the serious weight penalty imposed by an ejector seat, the engineers refused to install this equipment, resulting in a serious disagreement between the test pilots and the manufacturers.
The Focke-Wulf was not only faster but its superior handling and faster roll rate gave it an edge in the hands of even less experienced pilots. Such sparkling performance combined with the 190's superior armament presented Allied pilots with a real challenge until German pilot training began to drop in quality. The standard Fw 190A was quickly modified to perform a number of roles, particularly that of fighter-bomber in the F and G versions. These deleted the outer 20 mm cannon in favor of various combinations of bomb racks or cannon pods for the MK 103 30 mm cannon. Later versions of the FW 190A featured up to six 20 mm cannon (FW 190A6R1); the A-6/R-6 had two 210 mm (8.27 in) unguided rockets with which to attack US heavy bombers. The wide track landing gear assured ease of handling on takeoff and landing, unlike the twitchy Messerschmitt 109. The 190 was also one of the first fighters to feature a clear rear canopy, allowing pilots to keep an excellent lookout for enemy fighters.
Meanwhile, the Fw 190 was also proving a good fighter-bomber, carrying a reasonable bomb load or, in some cases, rocket projectiles. The new war started by Hitler on the Eastern Front resulted in most of the new production Fw 190s being thrown into the fighting against the Russians. Others were needed equally urgently by Rommel in North Africa, to combat the Western Desert Air Force and Allied ground forces who, by the latter part of 1942, were pressing hard at Alamein.
As RAF and USAAF bombing raids got heavier and heavier in Europe, new tactics were employed by some German fighter units flying Fw 190s. Against US heavy bombers on daylight raids, several Fw 190s would form a queue and approach from the rear of the bomber formation. At very close range, the fighters would then 'open up,' so giving the rear gunners in the bombers very little chance of firing methodically at all the attackers.
During 1943, the Fw 190 was encountered frequently in Europe while performing night fighter missions. About the same time, the first Fw 190s came off the production line fitted with inline, rather than radial, engines. General appearance stayed the same, because of the use of an annular radiator at the nose.
The new Junkers Jumo 213 powerplant made the aircraft, once again, the fastest Luftwaffe operational fighter and those pilots with the skill to use such advantages did very well. Unfortunately excellent fighter designs could not compensate for poor production standards, lack of fuel, poor pilot training and overwhelming Allied numerical superiority.
In honor of designer Kurt Tank, the Fw 190's designation was changed to Tank or Ta 152. This beautiful inline-engined fighter was to be the ultimate version of the famous fighter but delays resulted in the stopgap Fw 190D, in itself an outstanding aircraft. In the chaotic final year of the Third Reich the D ended up being the major inline engine version with only a few Ta 152Hs, and possibly a few Ta 152Cs, getting into combat.
The extended wing (14.5m), high altitude Ta 152H was indeed a sterling performer with a top speed of 755 km/h (472 mph) and a service ceiling of 15,000 m (49,215 ft). It was armed with a 30 mm cannon in the nose and two 20 mm cannon in the wing roots. Had it been built in enough numbers and been flown by expert pilots it could have taken its place alongside the Me 262 as a near unbeatable air superiority fighter and bomber killer. The lower altitude version, the Ta 152C, barely made it out of the test phase before the war ended. Between October 1944 and February 1945 when production ended, Focke-Wulf managed to roll 67 completed Ta 152 aircraft (H-0, H-1, and C-1 models) off the line. By the end of the war, more than 20,000 Fw 190s had been built; about one-third as fighter bombers.
General characteristics(Fw-190 A-8)
* Crew: 1 * Length: 9.00 m (29 ft 5 in) * Wingspan: 10.51 m (34 ft 5 in) * Height: 3.95 m (12 ft 12 in) * Wing area: 18,30 m² (196.99 ft²) * Empty weight: 3,200 kg (7,060 lb) * Loaded weight: 4,417 kg (9,735 lb) * Max takeoff weight: 4,900 kg (10,800 lb) * Powerplant: 1× BMW 801 D-2 radial engine, 1,250 kW (1,700 PS) , 1,471 kW (2,000 PS) with boost
* Maximum speed: 656 km/h (408 mph) at 19,420 ft (5,920 m), 408 mph (657 km/h) with boost * Range: 800 km (500 mi) * Service ceiling: 11,410 m (37,430 ft) * Rate of climb: 13 m/s (2,560 ft/min) * Wing loading: 241 kg/m² (49.4 lb/ft²) * Power/mass: 0.29-0.33 kW/kg (0.18-0.21 hp/lb)
* Guns: * 2 × 13 mm (.51 in) MG 131 machine guns with 475 rpg * 4 × 20 mm MG 151/20 E cannons with 250 rpg in the wing root and 140 rpg outboard.
General characteristics (Fw-190 D-9)
* Crew: 1 * Length: 10.20 m (33 ft 5½ in) * Wingspan: 10.50 m (34 ft 5 in) * Height: 3.35 m (11 ft 0 in) * Wing area: 18.30 m² (196.99 ft²) * Empty weight: 3,490 kg (7,694 lb) * Loaded weight: 4,350 kg (9,590 lb) * Max takeoff weight: 4,840 kg (10,670 lb) * Powerplant: 1× Junkers Jumo 213 A-1 12-cylinder inverted-Vee piston engine, 1,287 kW, (1,750 PS) , 1,544 kW (2,100 PS) with boost
* Maximum speed: 685 km/h (426 mph) at 6,600 m (21,655 ft), 710 km/h (440 mph) at 37,000 ft (11,000 m) * Range: 835 km (519 mi) * Service ceiling: 12,000 m (39,370 ft) * Rate of climb: 17 m/s (3,300 ft/min) * Wing loading: 238 kg/m² (48.7 lb/ft²) * Power/mass: 0.30–0.35 kW/kg (0.18–0.21 hp/lb)
* Guns: o 2 × 13 mm (.51 in) MG 131 machine guns with 475 rpg o 2 × 20 mm MG 151 cannons with 250 rpg in the wing root * Bombs: 1 × 500 kg (1,102 lb) SC 500 bomb (optional)
