TARANIS BAE Stealth Jet
Lucas (netAirspace ATC & Founding Member) 12 Jul 10, 23:27Post
Saw this bit in the news, and it was the first I recalled hearing of it. What do you lot think? I'm surprised that it's being produced. I suppose it will be mainly a EU sort of deal?
Also, what's with the little pointy things. They make it look bigger than it is, as it's really quite small.
http://www.dailymail.co.uk/sciencetech/article-1294037/Taranis-The-143million-unmanned-stealth-jet-hit-targets-continent.html
Defence firm BAE Systems today officially unveiled its first ever high-tech unmanned stealth jet.
The Taranis, named after the Celtic god of thunder, is about the same size as a Hawk jet and is equipped with stealth equipment and an 'autonomous' artificial intelligence system.
The plane will test the possibility of developing the first ever autonomous stealthy Unmanned Combat Air Vehicle (UCAV) that would ultimately be capable of precisely striking targets at long range, even in another continent. Taranis, the prototype of an unmanned combat aircraft of the future, which was unveiled today
The trial aircraft cost £143 million pounds to construct and spearheads BAE's drive to convince the Ministry of Defence to invest in the next generation of unmanned aircraft.
Almost invisible to ground radar, it is designed to travel at high jet speeds and cover massive distances between continents.
The plane is built to carry out intelligence, surveillance and reconnaissance on enemy territory using onboard sensors.
And it has been designed to carry a cache of weapons - including bombs and missiles -, giving it a potential long-range strike capability.
It can be controlled from anywhere in the world with satellite communications.
Experts say the cutting-edge design is at the forefront of world technology and as advanced as any US development.
The plane began development in December 2006, and is intended to prove the UK's ability to produce a stealthy UAV.
Taranis will be stealthy, fast, able to carry out use a number of on-board weapons systems and be able to defend itself against manned and other unmanned enemy aircraft.
Queso (netAirspace ATC Tower Chief & Founding Member) 13 Jul 10, 00:17Post
Lucas wrote:Also, what's with the little pointy things.
The picture was taken in a radar test chamber, those "little pointy things" are used to absorb and dissipate RF energy that is reflected around so that an accurate measurement of the RCS of the vehicle can be made. If you've ever seen a close-up of the leading edges of the SR-71's wings and the edges of the canopy on the F-117, you'll see that same kind of pattern.
SR-71 wing.jpg (24.31 KiB) Viewed 415 times
Lucas (netAirspace ATC & Founding Member) 13 Jul 10, 01:08Post
Ahh, I thought it looked something like acoustic chambering, so that makes sense. Thanks for the answer, Queso.
Queso (netAirspace ATC Tower Chief & Founding Member) 13 Jul 10, 01:28Post
Lucas wrote:Ahh, I thought it looked something like acoustic chambering, so that makes sense. Thanks for the answer, Queso.
Right! Technically, it's called a "anechoic chamber". Here's a picture of another one....
Lucas (netAirspace ATC & Founding Member) 14 Jul 10, 20:25Post
I'll be honest, that's some awesome crap right there. I need a room like that in my house.
