McDonnell Douglas F-4 Phantom II
miamiair (netAirspace FAA) 12 Mar 10, 16:22Post
* Crew: 2
* Length: 63 ft 0 in (19.2 m)
* Wingspan: 38 ft 4.5 in (11.7 m)
* Height: 16 ft 6 in (5.0 m)
* Wing area: 530.0 ft² (49.2 m²)
* Airfoil: NACA 0006.4-64 root, NACA 0003-64 tip
* Empty weight: 30,328 lb (13,757 kg)
* Loaded weight: 41,500 lb (18,825 kg)
* Max takeoff weight: 61,795 lb (28,030 kg)
* Powerplant: 2× General Electric J79-GE-17A axial compressor turbojets, 17,845 lbf (79.4 kN) each
* Zero-lift drag coefficient: 0.0224
* Drag area: 11.87 ft² (1.10 m²)
* Aspect ratio: 2.77
* Fuel capacity: 1,994 U.S. gal (7,549 L) internal, 3,335 U.S. gal (12,627 L) with three external tanks (370 U.S. gal (1,420 L) tanks on the outer wing hardpoints and either a 600 or 610 U.S. gal (2,310 or 2,345 L) tank for the centerline station).
* Maximum landing weight: 36,831 lb (16,706 kg)
* Maximum speed: Mach 2.23 (1,472 mph, 2,370 km/h) at 40,000 ft (12,190 m)
* Cruise speed: 506 kn (585 mph, 940 km/h)
* Combat radius: 367 nmi (422 mi, 680 km)
* Ferry range: 1,403 nmi (1,615 mi, 2,600 km) with 3 external fuel tanks
* Service ceiling: 60,000 ft (18,300 m)
* Rate of climb: 41,300 ft/min (210 m/s)
* Wing loading: 78 lb/ft² (383 kg/m²)
* lift-to-drag: 8.58
* Thrust/weight: 0.86 at loaded weight, 0.58 at MTOW
* Takeoff roll: 4,490 ft (1,370 m) at 53,814 lb (24,410 kg)
* Landing roll: 3,680 ft (1,120 m) at 36,831 lb (16,706 kg)
* Up to 18,650 lb (8,480 kg) of weapons on nine external hardpoints, including general purpose bombs, cluster bombs, TV- and laser-guided bombs, rocket pods (UK Phantoms 4 × Matra rocket pods with 18 × SNEB 68 mm rockets each), air-to-ground missiles, anti-runway weapons, anti-ship missiles, targeting pods, reconnaissance pods, and nuclear weapons. Baggage pods and external fuel tanks may also be carried.
* 4× AIM-7 Sparrow in fuselage recesses plus 4 × AIM-9 Sidewinders on wing pylons; upgraded Hellenic F-4E and German F-4F ICE carry AIM-120 AMRAAM, Japanese F-4EJ Kai carry AAM-3, Hellenic F-4E will carry IRIS-T in future. Iranian F-4s could potentially carry Russian and Chinese missiles. UK Phantoms carry Skyflash missiles[111]
* 1× M61 Vulcan 20 mm (.79 in) gatling cannon, 640 rounds
* 4× AIM-9 Sidewinder, Python-3 (F-4 Kurnass 2000), IRIS-T (F-4E AUP Hellenic Air Force)
* 4× AIM-7 Sparrow, AAM-3(F-4EJ Kai)
* 4× AIM-120 AMRAAM for F-4F ICE, F-4E AUP (Hellenic Air Force)
* 6× AGM-65 Maverick
* 4× AGM-62 Walleye
* 4× AGM-45 Shrike, AGM-88 HARM, AGM-78 Standard ARM
* 4× GBU-15
* 18× Mk.82, GBU-12
* 5× Mk.84, GBU-10, GBU-14
* 18× CBU-87, CBU-89, CBU-58
* SUU-23/A 20 mm (.79 in) gun pod
The F-4 is one of the most famous fighter aircraft of the post-World War II era, having been used in large numbers by the air forces of many western nations, where it gradually evolved in capability and mission diversity. First flown on 27 May 1958, the Phantom was developed as a private venture by McDonnell and was first ordered by the US Navy as a carrier-based attack aircraft armed with a 20-mm cannon (the F-4B). Soon after its introduction to active service in December 1960, a fly-off competition was conducted between the Phantom and various frontline Air Force fighters. The Phantom excelled in the competition in such a decisive way that the US Air Force ordered a slightly different version of the aircraft (the F-4C) and the Phantom went on to equip over three-quarters of the USAF's fighter wings.
US involvement in the war in Vietnam saw the F-4 utilized in an increasingly multi-role capacity, delivering bombs in huge multi-aircraft formations, shooting down North Vietnamese MiGs, and earning its rightful place in history. Improvements in the aircraft's electronic systems, engines and airframe resulted in many variants, including the F-4E (with more powerful engines, leading-edge wing slats to improve maneuverability, and 20-mm cannon); the RF-4E (export version designed for tactical reconnaissance); the F-4F (air superiority version for the German Luftwaffe, with air-to-ground weapons system removed); the F-4G ("Wild Weasel" anti-missile version); and the F-4K/M (Royal Navy/Royal Air Force versions, respectively).
The latest variant, and certainly the last, are the QF-4N pilot-less target drones operated by the Pacific Missile Test Center at Point Mugu, California. In addition to several F-4s still in active service with the Lufwaffe at Holloman AFB, New Mexico, and several others performing civilian-contract test work at Mojave, California, a sole privately operated F-4 was made airworthy in the 1990s in the USA, thanks to the hard work of both the USAF and the Collings Foundation. Flown by USAF Vietnam ace General Steve Ritchie, this F-4 is flown at airshows around the USA as an extremely effective recruiting tool for the Air Force. (See photo above.)
The F-4 remains in service in several nations around the world, including Germany, Japan, Greece, Turkey and South Korea.
In German:
miamiair (netAirspace FAA) 12 Mar 10, 16:26Post
For our friends that flew them off their carriers too...
mark5388916 13 Mar 10, 16:17Post
I remember last summer I was with school at Pima Air And Space Museum. I had heard the whine of A-10s for a little bit, then I heard the building shake and roar, look outside to see a 2 ship of F-4s getting prepped to go out in a lovely ball of fire. What an experience that was!
