miamiair/forum/images/avatars/gallery/first/user54/1.pngoffline(netAirspace FAA) 10 Mar 10, 12:32
* Crew: One * Length: 45 ft 11 in (14.00 m) * Wingspan: 33 ft 8 in (10.26 m) * Height: 13 ft 2 in (4.01 m) * Wing area: 349 ft² (32.42 m²) * Empty weight: 14,122 lb (6,405 kg) * Loaded weight: 17,750 lb (8,050 kg) * Max takeoff weight: 24,600 lb (11,158 kg) * Powerplant: 1× Rolls-Royce Avon 207 turbojet, 10,145 lbf (45.13 kN)
* Maximum speed: Mach 0.94, 620 kn (715 mph, 1,150 km/h) at sea level * Combat range: 385 nmi (445 mi, 715 km) * Ferry range: 1,650 nmi (1,900 mi, 3,060 km) with external fuel * Service ceiling: 50,000 ft (15,240 m) * Rate of climb: 17,200 ft/min (87.4 m/s) * Wing loading: 51.6 lb/ft² (251.9 kg/m²) * Thrust/weight: 0.56
* Guns: 4× 30 mm (1.18 in) ADEN cannons in a removable gun pack with 150 rpg * Rockets: o 4× Matra rocket pods (each with 18 × SNEB 68 mm (2.68 in) rockets) or o 24× Hispano SURA R80 80 mm (3.15 in) rockets[19] * Missiles: o Air-to-air missile: 4× AIM-9 Sidewinder o Air-to-surface missile: 4× AGM-65 Maverick * Bombs: 7,400 lb (3,357 kg) of payload on 4× under-wing hardpoints (upgraded Singapore Hunters had 1× centreline & 6× under-wing hardpoints[17][18]), including a variety of unguided iron bombs and drop tanks for extended range.
Avionics
* Ekco Ranging radar
Variants (great trivia)
Hawker P.1067 Prototype, first flight 20 July 1951, three built with the first later modified as a Mark 3 for the succesful World Speed Record attempts.
Hawker P.1083 Supersonic design based on the P.1067 with 50 degree wing sweep and afterburning Avon engine. Construction abandoned and the fuselage and tail were used as basis for the P.1099.
Hawker P.1101 Two-seat trainer prototype, first flight 8 July 1955, two built.
Production Versions
Hunter F 1 First production version, Avon 113 engine, first flight 16 March 1953, 139 built.
Hunter F 2 Sapphire 101 engine, first flight 14 October 1953, 45 built by Armstrong Whitworth at Coventry.
Hunter Mk 3 Sometimes mistakenly called F3, but it carried no weapons. The first prototype fitted with afterburning Avon RA.7R with 9,600 lbf (42.70 kN) engine, pointed nose, airbrakes on the sides of the fuselage, and a revised windscreen. Used to set raise the world's absolute air speed record to 727.6 mph (1,171 km/h) off the English south coast on 7 September 1953, and days later to set a new 62 mi (100 km) circuit record. It was sold in 1955 and retired as an RAF ground instructional airframe. Now in the Museum at Tangmere, Sussex.
Hunter F 4 Additional bag-type fuel tanks in the wings, provision for underwing fuel tanks, Avon 115 (later Avon 121) engine, blisters under the nose for ammunition links, first flight 20 October 1954, 349 built.
Hunter F 5 F 4 with Sapphire 101 engine, 105 built by Armstrong Whitworth at Coventry
Hunter F 6 Single-seat clear-weather interceptor fighter. Powered by one 10,150 lbf (45.17 kN) Rolls-Royce Avon 203 turbojet engine, revised wing with a leading edge "dogtooth" and four hardpoints, and a follow-up tailplane on later aircraft (also rerofitted to the early production examples) to improve pitch response at high Mach number, first flight 22 January 1954, 384 built.
Hunter F 6A Modified F6 with brake parachute and 230 gallon inboard drop tanks, for use at RAF Brawdy, where diversion airfields were distant.
Hunter T 7 Two-seat trainer built for the RAF. A side by side seating nose section replaced the single seat nose. Engine and systems as for the F4; some were rebuilt F4s, others were new build. The dog-tooth leading edge and follow-up tailpane mods, as on the F6, were fitted to the T7.
Hunter T 7A T 7 modified with the Integrated Flight Instrumentation System (IFIS). Used by the RAF as a Blackburn Buccaneer conversion training aircraft.
Hunter T 8 Two-seat trainer for the Royal Navy. Fitted with an arrestor hook for use on RN airfields but otherwise similar to the T 7
Hunter T 8B T 8 with TACAN radio-navigation system and IFIS fitted, cannon and ranging radar removed. Used by the Royal Navy as a Blackburn Buccaneer conversion training aircraft.
Hunter T 8C T 8 with TACAN fitted.
Hunter T 8M T 8 fitted with the Sea Harrier's Blue Fox radar, used by the Royal Navy to train Sea Harrier pilots.
Hunter FGA 9 Single-seat ground-attack fighter version for the RAF; all were modified from F6 airframes. Strengthened wing, 230 gallon inboard drop tanks, tail chute, increased oxygen capacity, and bobweight in pitch control circuit to increase stick force in ground attack maneuvers.
Hunter FR 10 Single-seat reconnaissance version; all 33 were rebuilt F6 airframes, with 3 x F95 cameras, revised instrument panel layout, brake parachute and 230 gallon inboard drop tanks. Increased oxygen as for the FGA 9, but no pitch bobweight.
Hunter GA 11 Single-seat weapons training version for the Royal Navy. Forty ex-RAF Hunter F 4s were converted into the Hunter GA11. The GA 11 was fitted with an arrester hook and some later had a Harley light. The guns were removed.
Hunter PR 11 Single-seat reconnaissance version for the Royal Navy. The nose was as on the FR 10.
Hunter Mk 12 Two-seat test aircraft for the Royal Aircraft Establishment. One built, converted from an F6 airframe..
Export versions
Hunter Mk 50 Export version of the Hunter F 4 fighter for Sweden. Swedish designation J34, 120 built.
Hunter Mk 51 Export version of the Hunter F 4 fighter for Denmark, 30 built.
Hunter Mk 52 Export version of the Hunter F 4 fighter for Peru, 16 built.
Huter T 53 Export version of the Hunter T.7 trainer for Denmark, two built.
Hunter Mk 56 Export version of the Hunter F 6 fighter for India, 160 built.
Hunter FGA 56A Export version of the Hunter FGA 9 ground-attack fighter for India.
Hunter FGA 57 Export version of the Hunter FGA 9 ground-attack fighter for Kuwait.
Hunter Mk 58 Export version of the Hunter F 6 fighter for Switzerland.
Hunter Mk 58A Export version of the Hunter FGA 9 ground-attack fighter for Switzerland
Hunter FGA 59 Export version of the Hunter FGA 9 ground-attack fighter for Iraq.
Hunter FGA 59A 18 aircraft were sold to Iraq as part of a follow-on order.
Hunter FGA 59B Four aircraft were sold to Iraq as part of a follow-on order.
Hunter Mk 60 Export version of the Hunter F 6 fighter for Saudi Arabia.
Hunter T 62 Export version of the Hunter T 7 trainer for Peru.
Hunter T 66 Two-seat training version for the Indian Air Force, powered by a Rolls-Royce Avon 200-series turbojet engine.
Hunter T 66A A composite Hunter, built from a damaged Belgian F6 bought back by the company, and a 2-seat nose originally built for display at the Paris Salon. Used as a demonstration aircraft, registered G-APUX. Finished in red and white, and used for promotional displays and in evaluations. Later sold to Chile as a T 72.
Hunter T 66B Export version of the Hunter T 66 trainer for Jordan.
Hunter T 66C Export version of the Hunter T.66 trainer for Lebanon.
Hunter T.66D 12 aircraft sold to India as part of a follow-on order.
Hunter T 66E Five aircraft sold to India as part of a follow-on order.
Hunter T 67 Export version of the Hunter T 66 trainer for Kuwait.
Hunter T 68 Export version of the Hunter T 66 trainer for Switzerland.
Hunter T 69 Export version of the Hunter T 66 trainer for Iraq.
Hunter FGA 70 Export version of the Hunter FGA 9 ground-attack fighter for Lebanon.
Hunter FGA 70A Lebanon.
Hunter T 70 This was the unofficial designation given to two ex-RAF Hunter T 7s sold to Saudi Arabia.
Hunter FGA 71 export version of the Hunter FGA 9 ground-attack fighter for Chile.
Hunter FR 71A Export version of the Hunter FR 10 reconnaissance aircraft for Chile.
Hunter T 72 Export version of the T 66 trainer for Chile.
Hunter FGA 73 Export version of the Hunter FGA 9 ground-attack fighter for Jordan.
Hunter FGA 73A Four aircraft sold to Jordan as part of a follow-on order.
Hunter FGA 73B Three aircraft sold to Jordan as part of a follow-on order.
Hunter FGA 74 12× Export version of the Hunter FGA 9 ground-attack fighter for Singapore, upgraded in late 1970's and re-designated as Hunter F 74S.
Hunter FR 74A 4× Export version of the Hunter FR 10 reconnaissance aircraft for Singapore, upgraded in late 1970's and re-designated as Hunter FR 74S.
Hunter FR 74B 22× aircraft delivered to Singapore as part of a follow order, upgraded in late 1970's and re-designated as Hunter FR 74S.
Hunter T 75 4× Export version of the Hunter T 66 trainer for Singapore, upgraded in late 1970's and re-designated as Hunter T 75S.
Hunter T 75A 4× aircraft delivered to Singapore as part of a follow-on order (A fifth aircraft was lost in an accident before delivery), upgraded in late 1970's and re-designated as Hunter T 75S.
Hunter FGA 76 Export version of the Hunter FGA 9 ground-attack fighter for Abu Dhabi.
Hunter FR 76A Export version of the Hunter FR 10 reconnaissance aircraft for Abu Dhabi.
Hunter T 77 Export version of the Hunter T 7 trainer for Abu Dhabi.
Hunter FGA 78 Export version of the Hunter FGA 9 ground-attack fighter for Qatar.
Hunter T 79 Export version of the Hunter T 7 trainer for Qatar.
Hunter FGA 80 Export version of the Hunter FGA 9 ground-attack fighter for Kenya.
Hunter T 81 Export version of the Hunter T 66 trainer for Kenya.
