Bronco II - Maybe Headed For USAF
miamiair (netAirspace FAA) 07 Jan 19, 17:50Post
Queso (netAirspace ATC Tower Chief & Founding Member) 07 Jan 19, 21:29Post
Oh yeah, let's go out on a low-to-medium altitude observation mission!
"No need for two engines", they said.
"No need for armor", they said.
JLAmber (netAirspace ATC & Founding Member) 07 Jan 19, 21:43Post
Surely this type of design is redundant due to the advancements in UAV technology? What's the point in risking two personnel to do a job that can be done from the comfort of a control room at far lower cost and risk to life?
miamiair (netAirspace FAA) 08 Jan 19, 11:45Post
The UAV doesn't work in the close-in air support role. I think this is a novel concept, but not for the role they are going to propose for it.
The original Bronco is a fascinating aircraft, it can use a revamp, new engines, new avionics, new weapon systems. Just like the adage: "What is going to replace the A-10?"
Easy, "Another A-10!"
Florida Metal 11 Mar 19, 05:14Post
Just wish someone could get the licensing to build new copies of the original OV-10
