The F-35 Sucks.
Queso (netAirspace ATC Tower Chief & Founding Member) 30 Jun 15, 18:05Post
I wanted to title this thread the same as the article it's quoting, "The F-35 Can't Beat The Plane It's Replacing In A Dogfight: Report", but of course our title lines won't take anything that long so I just abbreviated it. :))
Helluva read at: http://foxtrotalpha.jalopnik.com/the-f- ... 1714712248
We’ve heard of significant shortcomings before with the fighter jet that’s supposed to be America’s future, but this is just as bad as it gets. The F-35 performed so dismally in a dogfight, that the test pilot remarked that the it had pretty much no place fighting other aircraft within visual range.
And it’s even worse than a mere maneuverability issue. At one point, the pilot’s helmet was so big he couldn’t even turn his head inside the cockpit.
That’s according to a scathing report obtained by our friends over at War Is Boring that details the results of visual range air-to-air engagement tests between an F-35A and an F-16C. The F-35, which the US Air Force, Navy, and Marines are expected to rely upon, in addition to the air arms of militaries across the world for at least the next few decades, was supposed to be better than its F-16 predecessor in all respects.
The F-35’s ability to compete against other fighter aircraft in a close-in dogfight, even against the decades old designs it looks to replace, has always been a contentious issue. Long ago, the F-35’s maneuverability was planned to far exceed that of fourth generation fighters. Over time, those claims eroded to the point where the troubled stealth jet is described as being “about as maneuverable as an F-16.”
The fact that the F-35 can carry its weapons and fuel internally was of course the major deciding factor in being able to make such a claim.
Keep in mind, all of this is anecdotal, but testing reports over almost the last decade have supported the fact that the F-35 was not nearly as nimble as many would like it to be. Still, all claims regarding its performance against other fighters in a dogfight remained largely academic, with only bits of data to compare in a vacuum.
Which is why the candid report described in the War Is Boring article finally gives us a good first hand account as to how capable – or incapable as it may be – the F-35 is in the within-visual-range fight.
The test pilot flying the F-35 makes it very clear that the new jet, even in its ideal configuration without any external stores, was no match against a Block-40 F-16C in a less-than-ideal configuration with a pair of under-wing fuel tanks:
Even with the limited F-16 target configuration, the F-35A remained at a distinct energy disadvantage for every engagement.
In dogfighting, energy is everything, and if your enemy has more kinetic and potential energy for maneuvers than you do, then you’re toast.
The report even goes into what is akin to a fairly desperate move usually only used in one-on-one air combat maneuvers, known as a rudder reversal, that the F-35 is apparently decent at performing at slow speeds. The fact that this was even detailed in the report as a useful tactic is telling. In reality, using such maneuvers means you are probably going to die if any other bad guys are in the area as it rapidly depletes the aircraft’s energy state, leaving it vulnerable to attack.
Another area that the test pilot highlights on is the F-35’s abysmal rearward visibility. David Axe from War Is Boring writes:
And to add insult to injury, the JSF flier discovered he couldn’t even comfortably move his head inside the radar-evading jet’s cramped cockpit. “The helmet was too large for the space inside the canopy to adequately see behind the aircraft.” That allowed the F-16 to sneak up on him.
The report goes on to make other telling remarks about the F-35’s air combat maneuvering performance. It should be noted that the aircraft’s flight software can probably still be tweaked to offer a little wider envelope for pilots to traverse during a hard turning dogfight, but seeing as this test occurred this year (almost a decade after the first F-35 flew), the amount of extra agility that can be squeezed out of the F-35 is most likely marginal at this point. Also, the aircraft flown in the test, an F-35A, is the most maneuverable F-35 variant of the lot, being capable of pulling 9g, while the carrier capable F-35C is capable of pulling 7.5g and the short takeoff and vertical landing variant, the F-35B, is only capable of pulling 7g.
I don't care what they do with the software, you can't argue with physics.
Read the rest of that story at the link I posted above. Also of note.... Major Obvious: F-35 Pilot Says A-10 Will Always Be Better At Air Support
F-35 pilot Major John Wilson said the obvious in an interview with Danish aviation reporters; the F-35 will never be as good as the A-10 at close air support. This 100 percent factual, non-news statement set off a string stupid news stories. Tomorrow’s headline: a dump truck will never be as good of a sports car as a Ferrari.
Many more real-world assessments of the "does nothing well, and everything mediocre" F-35 available at the above links.
JLAmber (netAirspace ATC & Founding Member) 30 Jun 15, 20:40Post
The problem with stealth and the computer-controlled surfaces required to keep a stealth-profile aircraft flying is that you can't build a fighter with any other over-riding characteristic other than stealth qualities. That means you can't build a tank a massive engine that can turn on its nose and is designed around the pilot. That's why the F-117 was, well, not exactly a success, and why the F-35 is showing some weaknesses.
The question is, do you build a flying tank that can dogfight anything and hope that you're never going to war with countries owning advanced ground-to-air defences, or do you hope a slightly sub-standard player that can sneak up on anybody is good enough.
One rumour I hear some years ago was that the British Harrier fleet was grounded not only because of budget concerns, but also because it made the incoming F-35s look decidedly underwhelming, and this seemingly frivolous expenditure on an aircraft at best only a match for its predecessor would be politically very awkward to explain away.
Click Click D'oh (Photo Quality Screener & Founding Member) 30 Jun 15, 22:36Post
Well, you can build a stealthy super fighter. Look at the F-22. By all reports, it's the closest thing you can come to cheating with jet fighters.
The problem with the F-35 is the design by comittee nature of modern defense procurement that came about because of the success of the F-16 and F-18 as multirole aircraft. Unfortunately, the people that follow that line of thinking forget that both the F-16 and F-18 were designed as light day fighters and learned the multirole trick later. Heck, one of the most capable ground attack fighters today, the F-15E, started life with the motto "Not a pound for air to ground". The F-35 on the other hand was intended to be a carrier capable light fighter close air support bomb truck harrier with internal weapon stores.... Oh, and cheap. It's no wonder the resulting airframe is a flying turd.
It's a waste of money that will never be cancelled because too many congresscriters have their fingers in the pot. The USAF would have been much better if form the start they had just taken the F-15 ACTVIE program and combined it with the Silent Eagle. Then you would have had a very well proven airframe with the addition of thrust vectoring and high alpha maneuverability, a fair share of stealth and the ability to drop a decent bomb load if needed. Couldn't do that could we?
Lucas (netAirspace ATC & Founding Member) 01 Jul 15, 09:08Post
FYI, the F-35 has (maybe, I'm in the military, after all) pissed off most people with lucid cognition in the USAF. Imagine a young trainee starting in boot camp, and within two weeks hearing MTIs kvetching about the stupidity of the F-35, the waste of money it was, and the number of people that it would ultimately get needlessly killed. Of course, that trainee, later turned airman, may also have heard some ATC instructor say, "Yeah, I'm going to Nellis, so I'll probably wash out. Too bad I'm not going to Andrews so I can vector some jet into the W...well, you know. Doing the country some good."
But probably not, right?
Anyway, yeah, what a boondoggle.
