A400M Crash Near Seville
JLAmber (netAirspace ATC & Founding Member) 09 May 15, 12:28Post
An A400M, reportedly belonging to the Spanish Air Force, has crashed near SVQ. Reports are that 7 crew were onboard and the images coming in do not look good:
http://www.huffingtonpost.co.uk/2015/05 ... _hp_ref=tw
Reason: Removed "Breaking"
JLAmber (netAirspace ATC & Founding Member) 09 May 15, 13:19Post
The flight was showing under a CASA(EADS) callsign, so was probably a test/delivery flight out of Seville. Because it's a military aircraft there is no official confirmation yet.
FR24 are reporting that the vertical speed of changed quickly from +1664 feet/m to -2944 ft/m. From an altitude c.1200ft, they went down hard {vsad}
Zak (netAirspace FAA) 09 May 15, 14:45Post
http://www.netairspace.cc/news/article ... ar-seville
Zak (netAirspace FAA) 09 May 15, 14:58Post
Photo from the crash site
Source: Facebook / Yestay Manasbaev
Queso (netAirspace ATC Tower Chief & Founding Member) 09 May 15, 15:58Post
FR24 said 53 minutes ago on their Facebook feed that the plane was intended for the Turkish Air Force.
HT-ETNW 09 May 15, 19:23Post
According to the flight path shown in http://www.aero.de/news-21667/Airbus-A4 ... uerzt.html it appears that the crash occurred only minutes after having become airborne.
Lucas (netAirspace ATC & Founding Member) 10 May 15, 01:57Post
Says there were actually a bunch of survivors.
Lucas (netAirspace ATC & Founding Member) 10 May 15, 02:25Post
vikkyvik 10 May 15, 04:33Post
Flight path with speed:
http://pbs.twimg.com/media/CEkRwL_WIAE5D-F.png:large
Interesting. It didn't plummet to the ground. Took about 1:15 to go from 1700 feet to zero (granted, the sink rate increased significantly in the last 400 feet or so). But the speed did decay by about 25 knots right at the initial transition from climb to descent.
An issue with flap retraction, perhaps?
HT-ETNW 11 May 15, 10:08Post
aero.de is citing one of the two Airbus´ staff, who survived the crash, that "engine problems" were experienced inflight.
graphic 11 May 15, 21:09Post
That is one weird looking ground scar.
JLAmber (netAirspace ATC & Founding Member) 12 May 15, 21:42Post
One of the trade union managers from Seville has stated that the pilots managed to direct the aircraft away from a large factory and a school, instead aiming for a field when they realised that a return to the airport wasn't going to happen.
Airbus meanwhile have suspended the test-flight program for all pre-delivery frames.
vikkyvik 15 May 15, 23:32Post
JLAmber wrote:One of the trade union managers from Seville has stated that the pilots managed to direct the aircraft away from a large factory and a school, instead aiming for a field when they realised that a return to the airport wasn't going to happen.
I don't mean to be harsh on the pilots, but of course they're going to try for a field if one is available. A large factory and/or school aren't great places to try and land.
I just always find the comments of "the pilots tried to avoid this or that" right after an air crash pointless speculation. None of us know what exactly they were trying or able to do, at this point.
Anyway, off my soapbox.
graphic wrote:That is one weird looking ground scar.
Are the ones going off to the right from emergency vehicles? That was my first thought.
ShyFlyer (Founding Member) 15 May 15, 23:41Post
vikkyvik wrote:Are the ones going off to the right from emergency vehicles?
They came on seen from the left, judging by tire tracks. The scar going off to the right is far to wide and straight.
graphic 17 May 15, 00:59Post
I believe the aircraft also came in from the lower left as can be seen by the outline of the tail, and then the ground scar to the right was possibly caused by wind blowing the smoke and burning debris while the fire was still at very high intensity.
ShyFlyer (Founding Member) 17 May 15, 01:06Post
graphic wrote:then the ground scar to the right was possibly caused by wind blowing the smoke and burning debris while the fire was still at very high intensity.
That's [i]possible[/], but that scar on the right seems far too straight. And long. {boggled}
Zak (netAirspace FAA) 19 May 15, 09:46Post
German "Spiegel Online" reports that the crash was caused by a software error. A bug caused 3 of the 4 engines to be switched off shortly after takeoff.
Source (German): http://www.spiegel.de/politik/ausland/a ... 34421.html
miamiair (netAirspace FAA) 19 May 15, 10:02Post
Zak wrote:German "Spiegel Online" reports that the crash was caused by a software error. A bug caused 3 of the 4 engines to be switched off shortly after takeoff.
I guess there was no procedure in the QRH for CTRL + ALT + DEL. Too much when the machine has so much control.
Zak (netAirspace FAA) 19 May 15, 10:16Post
There usually is an override function, but that shortly after takeoff, they probably did not have the time to execute it.
miamiair (netAirspace FAA) 19 May 15, 10:24Post
Zak wrote:There usually is an override function, but that shortly after takeoff, they probably did not have the time to execute it.
If it is that complicated, they needed ejection seats. I know, not feasible, but somewhere, some code monkey and his supervisor is getting reamed, and rightfully so.
bhmbaglock 19 May 15, 12:04Post
Points to the Spanish AF for sticking to their guns regarding resumption of test flights. If this is true, the arrogance of Airbus Military in attempting to continue flights should result in a major housecleaning.
miamiair (netAirspace FAA) 19 May 15, 12:38Post
Airbus warns of glitch that could affect A400M engines
Airbus on Tuesday warned of a technical glitch potentially affecting the engines of its A400M that was discovered during an internal test after one of the military planes crashed in Spain.
The company said in a statement it had sent out an alert to its clients urging them to carry out "specific checks of the Electronic Control Units (ECU) on each of the aircraft's engines."
The ECU controls how the aircraft's engine operates.
miamiair (netAirspace FAA) 11 Jun 15, 14:49Post
From the Oops file:
Fatal A400M crash linked to data-wipe mistake
It said the focus of the inquiry was a theory that files known as "torque calibration parameters" had been accidentally deleted during a software installation process ahead of the plane's first flight.
BBC Link
Queso (netAirspace ATC Tower Chief & Founding Member) 11 Jun 15, 15:11Post
And no backup system or internal software generated checksums to generate errors before flight is commenced.
Disturbing.
This could be criminal negligence on part of the software developers. Are they the same group who were responsible for the software used on the first Ariane 5?
MD11Engineer 11 Jun 15, 17:15Post
Queso wrote:And no backup system or internal software generated checksums to generate errors before flight is commenced.
Disturbing.
Nope. The engine software came most likely from Rolls Royce. All the Airbus techs did then was to upload it into the ECUs as per AMM.
Jan
