ShyFlyer wrote:Should be fun. It will be the largest vehicle I've driven so far.
Great fun. You're big enough that you can out-douchebag the douchebags. I could tell stories... Suffice to say that there are few forms of automotive revenge quite as satisfying as grinning down at someone through his sunroof as his newly-terrified
SO kicks off at him.
Sounds obvious, but the way that sucker drives from their lot to your place isn't going to be the way it drives the rest of the trip. I nearly came a cropper when I got sloppy 4 hours into helping Woman's
BFF move her crap and started leaving empty-van braking distances.
Also obvious, load the thing properly. The girls wanted to leave the heavy stuff till last because it was hard, which would have meant having it all stacked roof-high in one corner at the back.
If I have to do it again, I'll probably welly the brakes as soon as I can after setting out. Gets everything nicely slid to the front and bedded in, and gives me a better idea of how it'll stop when (not if) some arsehole makes it necessary. Also stops that annoying rattle - because something
WILL rattle.
ORFflyer wrote:It will burn more fuel than you are expecting.
Especially when you realise that you left your wallet in a gas station an hour ago.
