Hi all
I'm just breaking in my new EOS70D and have a question for any of you guys who use Canon models with the fancy autofocus area choice.
Which of the three AF area choices would you normally use when spotting?
I've tried with Auto but, in particular on approach shots (aircraft nose on at approx 45 degrees) there seems to be a distinct lack of sharpness on the front and rear of the aircraft.
I wonder if I should be using the Zone AF setting (central zone selected?) for better results.
Lens used is the Canon 70-300mm f4-5.6 IS USM which I've been using on my 400D for the last five years with no issues.
Ideas appreciated.
Thanks.
