Getting This Error When Searching Images
darrenvox 08 Nov 23, 22:22Post
"General Error
SQL ERROR [ mysqli ]
Unknown column 'o.name' in 'where clause' [1054]
An SQL error occurred while fetching this page. Please contact the Board Administrator if this problem persists."
if someone could please fix that soon that would be great
https://darrensfs9site.weebly.com
ShanwickOceanic (netAirspace FAA) 08 Nov 23, 23:27Post
Thanks for that. Doing some much-needed performance improvements and missed a bit. Let me know if you see this again.
D-OTTI 09 Nov 23, 09:26Post
The same problem appears by private area opening.
ShanwickOceanic (netAirspace FAA) 09 Nov 23, 10:42Post
Private area opening? I don't understand. Can you post a link?
User profile? Yeah, that's bad. Fixed it.
D-OTTI 09 Nov 23, 11:57Post
Hi, another problem have to be fixed please. It´s impossible to "create and set" an edition.
Thank you.
ShanwickOceanic (netAirspace FAA) 09 Nov 23, 17:49Post
That one was ugly. Should be fixed now.
D-OTTI 19 Nov 23, 09:31Post
Hi, I´ve found another problem with DB. When you want to add an new entry for the DB without an existing photo then you got an empty field for the operator. When you later upload an image for this registration the operator is missing. Is happened me with N756YX. I could only solve the problem that I edited on the page "Airframe record new way".
Thanks in advance.
darrenvox 21 Nov 23, 15:02Post
search function works again flawlessly...
D-OTTI 04 Dec 23, 14:02Post
HI,
the problem still happens. You can generate for an airframe a new registration, is useful for Airbus with a preliminary registration, so I fill out the regular tail number, then is no more new editing after delivery needed but the airline is still blank. And when despite use it there appears an error by the airline field. I have attached a screenshot.
Screenshot 2023-12-03 091000.png (129.55 KiB) Viewed 1192 times
ShanwickOceanic (netAirspace FAA) 07 Dec 23, 11:55Post
I'm aware of the DB editing issue and am investigating. This one's gnarly. {crazy}
JLAmber (netAirspace ATC & Founding Member) 07 Dec 23, 19:32Post
ShanwickOceanic wrote:I'm aware of the DB editing issue and am investigating. This one's gnarly. {crazy}
If it helps, The error does not carry over to the DB once the image has been screened. It is solely in the DB Editing box(es).
Users browsing this forum: No registered users and 67 guests
