You are at netAirspace : Forum : Air and Space Forums : Aviation Sports & Hobby
New MS Flight Simulator, R U Getting It?
General Aviation, Air Races, Gliding, RC Aircraft, Model Collections, Flight Simulators.
miamiair (netAirspace FAA) 02 Nov 20, 12:21Post
So I got the damned thing. Question, is the 787 a default airplane? My version doesn't have it. I got the high end version, before you ask.
ShyFlyer (Founding Member) 02 Nov 20, 18:47Post
miamiair wrote:Question, is the 787 a default airplane?
Yes. Check the "Content Manager" under "Profile" to see if it's installed. Some versions for some people have had issues with default content not appearing/disappearing because for some reason it gets uninstalled when an update is applied.
Also make sure you're running the latest version. No clue as to the version number because it's ridiculously long, but if you haven't launched the sim since Sunday, there's a new one for you. That might fix things for you. Or maybe make things worse.
miamiair (netAirspace FAA) 04 Nov 20, 12:28Post
ShyFlyer wrote:Yes. Check the "Content Manager" under "Profile" to see if it's installed.
That worked fine, thanks for the tip.
ShyFlyer (Founding Member) 17 Nov 20, 16:00Post
Some strange things seen whilst over Greenland:
It's not "uncommon" to see some minor elevation errors. However, these "errors" reached all the way to FL290. I had to deviate to avoid hitting them.
Also noted whilst over the interior is that terrain was only rendered in a small area around me, much like the grand ol' days of FS98.
Lucas (netAirspace ATC & Founding Member) 23 Dec 20, 17:16Post
I am loving the game! NeoFly is awesome and I've been doing bush trips all around Idaho. The mapping system for the sim actions leaves much to be desired.
DXing 12 Jan 21, 01:09Post
The company I started working for offered the option to work from home. To do it was going to require purchasing a desktop with either 2 smaller or one large monitor. Took the opportunity to buy a pumped up desktop and a 27 inch monitor. No ulterior motive there... :)) Bought the game straight out of MS and have been fiddling around with it all afternoon. Still trying to figure my way out of the training flights but I have to say the scenery and interiors of the aircraft are superb compared to what I was used to. Well worth the money spent. Went with the middle of the road deluxe version version more because I wanted the DA60 than anything else. I enjoy the GA flying much more than airline. So far I haven't been disappointed but I wish there was a downloadable key assignment sheet. I also can't seem to figure out if you can assign your own call sign. Also, the sound controls to increase the aural alerts. But as I said, it's only the first day. I'm patient and it's a big program to get used too.
DXing 15 Jan 21, 04:05Post
So I've been flying around the northeastern U.S. the past couple of days in the DA60. Slowly but surely getting used to the controls. I read up thread that the autopilot needed some work and ain't that the truth! It's probably been the hardest thing to master, especially the vertical speed control. You can get way out of whack if you don't stay on top of it.
Is there anyway to do away with the ever present push crew? Today it was just straight ahead and make a left to get on the taxi line. I tried everything I could think of, and then just beheaded the guy on the pushback with the left wing as I pin wheeled out of the taxi stand.
The scenery is still fine by me although I too have seen some big rock monoliths standing out in the middle of nowhere.
miamiair (netAirspace FAA) 15 Jan 21, 12:48Post
Anti Ice
Toggle Anti Ice - H
Toggle Pilot Heat - SHIFT + H
Electrics
Toggle Master Alternator - ALT + A
Toggle Master Battery - ALT + B
Toggle Master Battery & Alternator - SHIFT + M
Engine Instruments
Decrease Cowl Flap - SHIFT + CTRL + C
Increase Cowl Flap - SHIFT + CTRL + V
Select Engine - E
Auto Start Engine - CTRL + E
Engine Autostop - SHIFT + CTRL + E
Magneto - M
Magnetos Both - SHIFT + ALT + F
Magnetos Left - SHIFT + ALT + S
Magnetos Off - SHIFT + ALT + Q
Magnetos Right - SHIFT + ALT + D
Magnetos Start - SHIFT + ALT + G
Toggle Master Ignition Switch - ALT + I
Flight Instruments
Select Airspeed Bug - SHIFT + CTRL + R
Select Altitude Bug - SHIFT + CTRL + Z
Toggle Autorudder - SHIFT + CTRL + U
Set Altimeter - B
Decrease Heading Bug - CTRL + DEL
Increase Heading Bug - CTRL + INSERT
Select Heading Bug - SHIFT + CTRL + H
Set Heading Indicator - D
Toggle Alternate Static - ALT + S
Fuel
Toggle Fuel Dump - SHIFT + CTRL + D
Fuel Selector 1 All - ALT + W
Fuel Selector 1 Off - CTRL + ALT + W
Toggle All Fuel Valves - ALT + V
Camera Keys
Slew Mode
Slew Translate Up (Slow) - F3
Slew Translate Up (Fast) - F4
Slew Translate Backward - NUM 2
Slew Translate Forward - NUM 8
Slew Translate Down (Fast) - F1
Slew Translate Down (Slow) - A
Slew Y-Axis Translation Freeze - F2
Slew Roll Left - NUM 7
Slew Roll Right - NUM 9
Slew X-Axis Translation Freeze - NUM 5
Slew Yaw Left - NUM 1
Slew Yaw Right - NUM 3
Slew Translate Left - NUM 4
Slew Pitch Down (Fast) - F8
Slew Pitch Freeze - F6
Slew Pitch Down - NUM 0
Slew Pitch Up - 9
Slew Pitch Up (Fast) - F5
Slew Pitch Up (Slow) - F7
Slew Translate Right - NUM 6
Toggle Slew Mode - Y
Camera Mode Switches
Cockpit/External View Mode - END
Toggle Drone - INSERT
Cockpit Camera
Load Custom Camera 0 - ALT + 0
Load Custom Camera 1 - ALT + 1
Load Custom Camera 2 - ALT + 2
Load Custom Camera 3 - ALT + 3
Load Custom Camera 4 - ALT + 4
Load Custom Camera 5 - ALT + 5
Load Custom Camera 6 - ALT + 6
Load Custom Camera 7 - ALT + 7
Load Custom Camera 8 - ALT + 8
Load Custom Camera 9 - ALT + 9
Load Next Custom Camera - K
Load Previous Custom Camera - SHIFT + K
Save Custom Camera 0 - CTRL + ALT + 0
Save Custom Camera 1 - CTRL + ALT + 1
Save Custom Camera 2 - CTRL + ALT + 2
Save Custom Camera 3 - CTRL + ALT + 3
Save Custom Camera 4 - CTRL + ALT + 4
Save Custom Camera 5 - CTRL + ALT + 5
Save Custom Camera 6 - CTRL + ALT + 6
Save Custom Camera 7 - CTRL + ALT + 7
Save Custom Camera 8 - CTRL + ALT + 8
Save Custom Camera 9 - CTRL + ALT + 9
Decrease Cockpit View Height - DOWN
Increase Cockpit View Height - UP
Translate Cockpit View Backward - RIGHT ALT + DOWN
Translate Cockpit View Forward - RIGHT ALT + UP
Translate Cockpit View Left - LEFT
Translate Cockpit View Right - RIGHT
Cockpit Look Down - SHIFT + DOWN
Cockpit Look Left - SHIFT + LEFT
Cockpit Look Right - SHIFT + RIGHT
Cockpit Look Up - SHIFT + UP
Cockpit Quickview Up - CTRL + UP
Cockpit Quickview Rear - CTRL + DOWN
Cockpit Quickview Right - CTRL + RIGHT
Cockpit Quickview Left - CTRL + LEFT
Cockpit Quickview Cycle - Q
Reset Cockpit View - CTRL + Space / F
Cockpit View Upper - Space
Unzoom Cockpit View - -
Toggle Smart Camera - S
Zoom Cockpit View - =
Drone Camera
Toggle Drone Depth Of Field - F1
Toggle Foreground Blur - F5
Drone Top Down View - CTRL + SPACE
Attach Drone To Next Target - CTRLl + PAGE UP
Attach Drone To Previous Target - CTRL + PAGE DOWN
Toggle Drone Auto Exposure - CTRL + F4
Toggle Drone Auto Focus - F4
Decrease Drone Rotation Speed - F3
Decrease Drone Translation Speed - F1
Decrease Drone Depth Of Field - F2
Increase Drone Depth Of Field - F3
Decrease Drone Exposure - CTRL + F2
Increase Drone Exposure - CTRL + F3
Increase Drone Rotation Speed - F4
Increase Drone Translation Speed - F2
Lock Drone To Next Target - T
Lock Drone To Previous Target - SHIFT + T
Translate Drone Backward - S
Translate Drone Down - F
Translate Drone Forward - W
Translate Drone Left - A
Translate Drone Right - D
Translate Drone Up - R
Reset Drone Roll - SPACE
Reset Drone Target Offset - NUM 5
Pitch Drone Down - NUM 2
Roll Drone Right - NUM 9
Pitch Drone Up - NUM 8
Yaw Drone Left - NUM 4
Yaw Drone Right - NUM 6
Roll Drone Left - NUM 7
Toggle Drone Follow Mode - TAB
Toggle Drone Lock Mode - CTRL + TAB
Increase Drone Zoom - NUM PLUS
Decrease Drone Zoom - NUM SUB
Toggle Plane Controls - C
External Camera
Reset External View - CTRL + SPACE / F
External Quickview Left - CTRL + LEFT
External Quickview Rear - CTRL + DOWN
External Quickview Right - CTRL + RIGHT
External Quickview Top - CTRL + UP
Unzoom External View - -
Zoom External View - =
Fixed Camera
Toggle Fixed Camera 10 - CTRL + SHIFT + 0
Toggle Fixed Camera 1 - CTRL + SHIFT + 1
Toggle Fixed Camera 2 - CTRL + SHIFT + 2
Toggle Fixed Camera 3 - CTRL + SHIFT + 3
Toggle Fixed Camera 4 - CTRL + SHIFT + 4
Toggle Fixed Camera 5 - CTRL + SHIFT + 5
Toggle Fixed Camera 6 - CTRL + SHIFT + 6
Toggle Fixed Camera 7 - CTRL + SHIFT + 7
Toggle Fixed Camera 8 - CTRL + SHIFT + 8
Toggle Fixed Camera 9 - CTRL + SHIFT + 9
Reset Fixed Camera - F
Previous Fixed Camera - SHIFT + A
Next Fixed Camera - A
Instrument Views
Previous Instrument View - SHIFT + A
Next Instrument View - A
Toggle Instrument View 10 - CTRL + 0
Toggle Instrument View 1 - CTRL + 1
Toggle Instrument View 2 - CTRL + 2
Toggle Instrument View 3 - CTRL + 3
Toggle Instrument View 4 - CTRL + 4
Toggle Instrument View 5 - CTRL + 5
Toggle Instrument View 6 - CTRL + 6
Toggle Instrument View 7 - CTRL + 7
Toggle Instrument View 8 - CTRL + 8
Toggle Instrument View 9 - CTRL + 9
Select Next POI - PGUP
Reset Smartcam - CTRL + F
Set Custom Smartcam Target - T
Next Smartcam Target - PGUP + CTRL
Camera AI Player - HOME + CTRL
Previous Smartcam Target - PGDOWN + CTRL
Toggle Follow Smartcam Target - PGDOWN
Unset Custom Smartcam Target - SHIFT + T
Autopilot Keys
Autopilot Airspeed Hold - Alt + R
Decrease Autopilot Reference Altitude - CTRL + PGDOWN
Increase Autopilot Reference Altitude - CTRL + PGUP
Toggle Autopilot Approach Hold - CTRL + A
Toggle Autopilot Attitude Hold - CTRL + T
Toggle Autopilot Localizer Hold - CTRL + O
Toggle Autopilot Mach Hold - CTRL + M
Toggle Autopilot Master - Z
Autopilot N1 Hold - CTRL + S
Decrease Autopilot N1 Reference - CTRL + END
Increase Autopilot N1 Reference - CTRL + HOME
Autopilot Nav1 Hold - CTRL + N
Decrease Autopilot Reference Airspeed - SHIFT + CTRL + DEL
Increase Autopilot Reference Airspeed - SHIFT + CTRL + INSERT
Decrease Autopilot Reference VS - CTRL + END
Increase Autopilot Reference VS - CTRL + HOME
Toggle Autopilot Wing Leveler - CTRL + V
Autopilot Off - SHIFT + ALT + Z
Autopilot On - ALT + Z
Arm Auto Throttle - SHIFT + R
Auto Throttle To GA - SHIFT + CTRL + G
Toggle Avionics Master - PGUP
Toggle Flight Director - CTRL + F
Toggle Yaw Damper - CTRL + D
Brake Keys
Brakes - NUM DECIMAL
Left Brake - NUMMULT
Right Brake - NUM SUB
Toggle Parking Brakes - CTRL + NUM DECIMAL
Flight Control Surface Keys
Primary Control Surfaces
Aileron Left (Roll Left - NUM 4
Aileron Right (roll Right) - NUM 6
Center Ailer Rudder - NUM 5
Elevator Down (Pitch Down) - NUM 8
Elevator Up (Pitch Up) - NUM 2
Toggle Water Rudder - CTRL + W
Rudder Left (Yaw Left) - NUM 0
Rudder Right (Yaw Right) - ENTER
Secondary Control Surfaces
Decrease Flaps - F6
Extends Flaps - F8
Increase Flaps - F7
Retract Flaps - F5
Toggle Spoilers - NUM DIVIDE
Control Trimming Surfaces
Aileron Trim Left - CTRL + NUM 4
Aileron Trim Right - CTRL + NUM 6
Rudder Trim Left - CTRL + NUM 0
Rudder Trim Right - CTRL + Enter
Elevator Trim Down (Nose Down) - NUM 7
Elevator Trim Up (Nose Up) - NUM 1
Landing Gear
Toggle Landing Gear - G
Gear Down - CTRL + G
Toggle Tail Wheel Lock - SHIFT + G
Lights Keys
Exterior Lights
Toggle Landing Lights - CTRL + I
Landing Lights Down - SHIFT + CTRL + NUM 2
Landing Light Home - SHIFT + CTRL + NUM 5
Landing Light Left - SHIFT + CTRL + NUM 4
Landing light Right - SHIFT + CTRL + NUM 6
Landing light Up - SHIFT + CTRL + NUM 8
Toggle Strobes - O
Toggle Beacon Light - ALT + H
Toggle Nav Light - ALT + N
Toggle Taxi Lights - ALT + J
Interior Lights
Toggle Flashlight - Alt + l
Toggle Lights - l
Menu Keys
Toggle Active Pause - PAUSE
Toggle Basic Control Panel - CTRL + C
Clear Search - DEL
Toggle Pause - ESC
Select 1 - Alt + F1
Select 2 - Alt + F2
Select 3 - Alt + F3
Select 4 - Alt + F4
Display Checklist - SHIFT + C
Next Toolbar Panel - .
Previous Toolbar Panel - /
Back To Main Menu - END
Close Menu - BACKSPACE
Fly - ENTER
Change Aircraft - F11
Liveries - F12
See Specifications - F10
Help Menu - TAB
Restart Free Flight - HOME
Restart Activity - HOME
Power Management Keys
Mixture
Decrease Mixture - SHIFT + CTRL + F2
Increase Mixture (Small) - SHIFT + CTRL + F3
Set Mixture Lean - SHIFT + CTRL + F1
Set Mixture Rich - SHIFT + CTRL + F4
Propeller
Decrease Propeller Pitch - CTRL + F2
Propeller Pitch Hi - CTRL + F4
Increase Propeller Pitch - CTRL + F3
Propeller Pitch Lo - CTRL + F1
Throttle
Throttle Cut - F1
Decrease Throttle - F2
Increase Throttle - F3
ADF
ADF - SHIFT + CTRL + A
Comms
Com Radio - C
Set Com1 Standby - SHIFT + ALT + X
Com1 Switch To Standby - ALT + U
DME
DME - F
NAV
Decrease NAV1 Frequency (Fract, Carry) - SHIFT + CTRL + PGDOWN
Increase NAV1 Frequency (Fract, Carry) - SHIFT + CTRL + PGUP
NAV1 Swap - SHIFT + CTRL + N
NAV Radio - N
VOR
Decrease VOR1 OBS - SHIFT + CTRL + END
Increase VOR1 OBS - SHIFT + CTRL + HOME
VOR OBS - SHIFT + V
XPNDR
Transponder - T
Set Transponder - SHIFT + ALT + W
Display ATC - Scroll Lock
ATC Panel Choice 0 - 0
ATC Panel Choice 1 - 1
ATC Panel Choice 2 - 2
ATC Panel Choice 3 - 3
ATC Panel Choice 4 - 4
ATC Panel Choice 5 - 5
ATC Panel Choice 6 - 6
ATC Panel Choice 7 - 7
ATC Panel Choice 8 - 8
ATC Panel Choice 9 - 9
Frequency Swap - X
Increase Wheel Speed - SHIFT
Miscellaneous Keys
Toggle Fuel Pump - ALT + P
Toggle Marker Sound - CTRL + 3
Minus - CTRL + NUM SUB
Plus - CTRL + NUM PLUS
Toggle Pushback - SHIFT + P
Request Fuel - SHIFT + F
Display Navlog - N
Display Map - V
Sim Rate - R
Skip RTC - BACKSPACE
New UI Window Mode - RIGHT ALT
Toggle Delegate Control To Copilot - CTRL + ALT + X
PA110 (Founding Member) 16 Jan 21, 05:22Post
My other half surprised the hell out of me for Christmas with a RealSimGear Garmin g1000 unit. Such a great experience using the unit and not have to try fussing with virtual knobs in turbulence.
I just tried VR for the first time today. Just a short flight from Kona to Hilo over the saddle in the DA62, my new favorite plane. Wow Wow Wow! Talk about an immersive experience! I felt like I was actually sitting in the cockpit. Being able to look around brought the game to a whole new level. The only problem with VR was I found myself reaching out into thin air to touch a cockpit that wasn't really there.
