You are at netAirspace : Forum : Spotting and Photography Forums : General Photography
New Canon camera body : EOS R
Non-aviation photos, camera equipment and photography in general.
airtrainer 06 Sep 18, 17:01Post
30.3mp Full Frame CMOS
Dual pixel CMOS AF
100% vertical x 88% horizontal AF coverage (We think)
EV -6 low brightness autofocus
4K video
Touchscreen LCD
Articulating screen
Wi-Fi
Bluetooth
Microphone jack
Headphone jack
Dustproof
Drip-proof
Magnesium body
Battery: LP-E6N
Battery grip: BG-E22
Size: Width of about 136 mm × height of about 98 mm
Weight: Approximately 580 g
Mount: inner diameter 54 mm, flange back 20 mm, 12 pin
Mount adapter: “Mount adapter EF – EOS R” “Control ring mount adapter EF – EOS R” “Drop – in filter mount adapter EF – EOS R”
Link : https://www.canonrumors.com/here-are-th ... nt-lenses/
airtrainer 06 Sep 18, 17:04Post
Fumanchewd 16 Sep 18, 02:23Post
I need new lenses for this mirrorless camera?
Edit: Have to buy an adapter mount, which will surely effect the lens. Eh.
Compatible with EF/EF-S Lenses*
Whether you're purchasing your first EOS camera or your fifth, the EOS R camera is designed to integrate smoothly into existing EOS systems. Engineered to work seamlessly with RF lenses, it maintains complete compatibility with EF and EF-S lenses by using one of three optional Mount Adapters. When using EF-S lenses, the EOS R even crops automatically to reflect the APS-C sized sensor the lenses are designed for.
"Give us a kiss, big tits."
