JeffSFO wrote:That's just the crop factor. You're not magically getting a closer view of the subject by having a 1.6 sensor instead of a 1.0, just a more narrow frame.
I know (and I've had this argument before
). But 15 MP on a 1.6 sensor will likely give me more effective range than 12 MP on a full frame. If detail resolution per pixel were the same, then the crop sensor would give me 1.6 times the range. Obviously it isn't the same, but I'd wager it still works out in crop sensor's favor in terms of range.
To me, it's simply the inverse of what happens at the short end. I know I'm still technically shooting at 17mm on my 50D, but the full-frame will still create a wider-angle image.
JeffSFO wrote:Finally, I always like to say: GO FULL FRAME OR GO HOME!
That's the idea.
How do you find the dynamic range and noise compared to newer cameras?
Thanks for the response.
