MasterOgon/forum/images/avatars/gallery/memberlevels/nonrev.pngoffline24 Aug 18, 03:30
The spacecraft with a propulsion on electric power. It will be fully controlled at hypersonic speeds when entering the atmosphere and can make a vertical landing without a parachute. In space, it can accelerate and maneuver with the help of an engine, using the wing as a sail.
Zak/forum/images/avatars/gallery/first/user2/2.pngoffline(netAirspace FAA) 24 Aug 18, 10:47
Do you have any additional information on the project? Did you build that prototype?
It certainly does look interesting. A bit odd, but interesting.
Спасибо!
MasterOgon/forum/images/avatars/gallery/memberlevels/nonrev.pngoffline24 Aug 18, 17:46
Yes, I built it. This is an aircraft with an inertial propulsion. The power is small, but the effect is better at speed.
