USMC C-130T Accident Video
miamiair (netAirspace FAA) 07 Dec 18, 15:20Post
Link To Report
Not a good way to go.
Lucas (netAirspace ATC & Founding Member) 07 Dec 18, 16:34Post
Good heavens.
paul mcallister 07 Dec 18, 18:39Post
That is terrifying,the crew had no chance.
GQfluffy (Database Editor & Founding Member) 08 Dec 18, 03:25Post
Those poor buggers...
Queso (netAirspace ATC Tower Chief & Founding Member) 12 Dec 18, 17:22Post
So a single prop blade failed on the #2 engine, and at almost the same time the gearbox failed on the #3 engine causing it to lose it's prop altogether.
Out of the 360 degrees the #2 prop's blade could have gone, it chose to go into the upper fuselage. Out of the 360 degrees the #3 prop could have gone, it chose to go into the upper fuselage.
That seems like one helluva coincidence.
miamiair (netAirspace FAA) 12 Dec 18, 17:45Post
Murphy, unless someone on the airplane was going to rat Hillary out...
GQfluffy (Database Editor & Founding Member) 12 Dec 18, 17:47Post
Do the props all spin the same direction on the C-130 or do they rotate opposite directions pending on what side of the fuselage they're on?
Idiotic question perhaps...but IIRC a Soviet aircraft did that...
miamiair (netAirspace FAA) 12 Dec 18, 18:00Post
GQfluffy wrote:Do the props all spin the same direction on the C-130 or do they rotate opposite directions pending on what side of the fuselage they're on?
They all spin in the same direction. The Airbus A400M has two spinning one way, the other two spin opposite.
Zak (netAirspace FAA) 12 Dec 18, 19:32Post
GQfluffy wrote:IIRC a Soviet aircraft did that...
You were probably thinking of the Tu-95. That one has contra-rotating dual-blade props:
https://en.wikipedia.org/wiki/Contra-ro ... propellers
