Apparently happened two weeks ago at Shaykovka Airbase:
https://aviation-safety.net/wikibase/wiki.php?id=199701Narrative:
The military plane had a technical failure and rolled of the runway during take off. The four crew members were not injured.
The Tu-22 Military Airplane pulled one wheel off the runway, "said the army, but the machine suffered no damage. Later it turned out that the crash was far more serious.
The machine pulled the chassis off the runway and ended up without gear. The left half of the wing with a variable geometry broke off. The machine is irreparably damaged.
Speed sensor malfunction could be the reason of the aborted takeoff.
Click Click D'oh wrote:If you listen carefully you can actually hear the sound of sphincters sucking up seat cushions right before it goes off the end of the runway.
Only thing I could hear were multiple loud screams of "CYKA BLYAT!"
