Less than two months after declaring the controversial F-35 Joint Strike Fighter ready for combat, the Air Force on Friday announced that it was temporarily grounding 15 of the jets after it discovered that insulation was “peeling and crumbling” inside the fuel tanks.
The Air Force said Friday that crews discovered that insulation in avionics cooling lines inside the fuel tanks was deteriorating.
KFLLCFII wrote:The Air Force said Friday that crews discovered that insulation in avionics cooling lines inside the fuel tanks was deteriorating.
Any other aircraft out there that use a similar arrangement for avionics cooling? Never heard of that before.
