The Bell-Boeing MV-22 Osprey tilt-rotor aircraft has successfully completed an initial test performing as an aerial refueling tanker. Adding this capability to the tiltrotor aircraft would further advance its versatility in support of Marine corps and naval aviation operations, as well as special operations in naval, combat, humanitarian and ship-based operations. In August 2013 the aircraft flew several demonstration flights over north Texas, with a V-22 equipped with a prototype aerial refueling system safely deployed, held stable, and retracted the refueling drogue as an F/A-18C and an F/A-18D Hornet flew just behind and to the side of the aircraft.
GQfluffy wrote:What Captain said...but I'm curious...I wonder if it would be able to lift enough fuel to refuel more than one Herky Bird...
