Dornier Do17 To Be Raised From The Channel
cornish (Certified Expert - Aviation Economics & Founding Member) 03 May 13, 11:12Post
An attempt is being made to raise the only known complete Dornier Do17 WW2 bomber from the bed of the English Channel, where it has laid since being shot down in 1940.
Work begins on Friday to raise a unique World War II aircraft from the floor of the English Channel just off the Kent coast. The Dornier 17 aircraft is the last of its kind, and lies in 50ft of water on the Goodwin Sands. The salvage is just the start of a two-year restoration project by the RAF Museum in Hendon.
more than 70 years on from the great air battles that saved Britain, not a single Dornier 17 was thought to have survived.
Then five years ago, a diver discovered the wreck of a plane, lying on its back in 50ft of water on the Goodwin Sands. Subsequent surveys confirmed it was a Dornier 17, and almost complete.
The RAF Museum resolved to salvage it and put it on display at its Hendon base. To do so its raised half a million pounds, including £345,000 from the National Heritage Memorial Fund.
Chris Goss, a military aircraft historian, says the find is "fantastic historically".
"This aircraft is going to be the only one of its type in existence in the world. There are little bits and pieces - the RAF Museum have a tail section, for one. But this aircraft is complete and therefore its price from a historical viewpoint is invaluable."
http://www.bbc.co.uk/news/uk-22380915
JLAmber (netAirspace ATC & Founding Member) 08 May 13, 11:10Post
Really interesting find, the Do-17 is a fine looking aircraft.
So the museum has built two polytunnels at its conservation centre at Cosford in the West Midlands, and equipped them with a system of spray nozzles. For the next 18 months the two halves of the aircraft - wings and fuselage - will be drenched in citric acid for 10 minutes out of every 30.
Essentially they're going to pickle an aircraft. I've never heard of that before, but whatever works.
miamiair (netAirspace FAA) 08 May 13, 11:32Post
The Do-17 "the Flying Pencil"
AndesSMF (Founding Member) 08 May 13, 14:35Post
JLAmber wrote:Essentially they're going to pickle an aircraft. I've never heard of that before, but whatever works.
I was thinking that it could be similar to what they did to the Vasa in Sweden, but this one is new.
ShanwickOceanic (netAirspace FAA) 11 Jun 13, 01:02Post
After some weather delays, they finally got it:
http://www.bbc.co.uk/news/uk-22846645
kmh1956 (Founding Member) 11 Jun 13, 02:05Post
ShanwickOceanic wrote:After some weather delays, they finally got it:
After 70-odd years, I think it's in amazingly good shape...
