Surgery on Friday
Mark 11 May 22, 16:17Post
On October 22, 2021, I passed out due to a syncopal episode while getting a panoramic x-ray at the dentist. I fractured the distal end of my left collarbone.
The docs, at the time, chose to see what it would do on its own in regard to healing. Well, it didn't heal at all. Essentially, I have a broken collarbone floating around my left shoulder with a little piece just sitting there. Nothing healed. The doc says I must have a high pain tolerance.
Below is the latest x-ray. The blue arrow points to the collarbone with the jagged end floating around. The yellow arrow points to the tip that broke off... that was supposed to heal to the piece shown by the blue arrow.
Friday morning, the orthopedist it going to connect the two pieces with a plate and screws.
I hope it's healed by the LAX meet.
miamiair (netAirspace FAA) 12 May 22, 12:37Post
Good luck, to a speedy recovery.
DXing 13 May 22, 07:30Post
Best of luck. Yep, you must have some grit to put up with that for as long as you have.
On the other hand, do you get to skip the magnetometer? Just a "friendly" pat down? {mischief} {duck}
Lucas (netAirspace ATC & Founding Member) 13 May 22, 14:54Post
Hope it went well!
Mark 14 May 22, 11:14Post
No pain!
Lucas (netAirspace ATC & Founding Member) 14 May 22, 13:23Post
Mark wrote:No pain!
That is fantastic news. Now no bucking hay for a while!
Mark 15 May 22, 18:03Post
Not too bad. A little numb. Aches at times. What isn't bruising is disinfectant and 3M Dermabond skin glue.
ShyFlyer (Founding Member) 15 May 22, 23:40Post
Happy to hear it turned out well & hope your fully recovered soon!
