AOG Technics Fake Parts Scandal Grows
DXing 26 Sep 23, 15:17Post
https://www.thedrive.com/news/fake-jet- ... ndal-grows
Looks like the scandal is growing, at least 4 major airlines seem to have gotten some parts from the now discredited company. I would think when the news first broke, MX management would have directed the staff to ensure that no parts from that company were in service on any of the aircraft in the fleet. I also wonder, and MiamiAir can shed more light, aren't parts obtained supposed to contain complete documentation from their manufacture to the airlines hands? How deep does a buyer check?
miamiair (netAirspace FAA) 26 Sep 23, 19:13Post
DXing wrote:...aren't parts obtained supposed to contain complete documentation from their manufacture to the airlines hands? How deep does a buyer check?
Remember one thing, cost is king. If it is cheap enough, some stringent buyers will bend their sight. Rotating engine parts are more scrutinized, and the word you're looking for is traceability. Consider it a birth certificate of a sorts, that should go from cradle to grave. Life-limited parts are similarly tracked with time & cycles, or time and cycles remaining. When you buy a part from an OEM, they will produce a document establishing the airworthiness of the part (FAA Form 8130-3 or EASA Form 1) is supplied, it stays with the aircraft/engine records until removed from service. Life limited parts need to be mutilated and scrapped to prevent any further use (Possibly what happened in this case). Quality manuals devote sections to this particular process. Sometimes, airlines purchase more spares than they need, so when they retire a particular aircraft/engine type, they will sell a parts lot, which should be supported with the proper documentation, along with supporting documents/contracts/purchase orders which will list the parts and provide a paper trail (traceability, remember?). In theory, this process is as strong as those willing to abide by the regulations and guidelines.
So you can get an idea:
Acceptability of Components/Parts. Describe the procedures to ensure that new component/parts consumed during maintenance on U.S.-registered aircraft and/or aircraft
components for the fitment onto U.S.-registered aircraft and foreign-registered aircraft operating under the provisions of 14 CFR have acceptable authorized release documents.
7.3.1 New Components.
7.3.1.1 New components/parts must be traceable to the PAH or DAH and be in a satisfactory condition for installation.
a. New parts manufactured outside of the territories of the United States are subject to the provisions of a bilateral agreement with the United States addressing the performance of design, production
approval, and airworthiness for the acceptance of that part.
b. New parts must be in a satisfactory condition for installation.
c. Airworthiness documentation required by the TIP associated with Annex 1 of the Agreement is acceptable for new parts.
d. Technical Standard Order (TSO) parts are acceptable on U.S.-registered aircraft with proper documentation.
e. New parts provided by a U.S. air carrier must have documentation in accordance with the U.S. air carrier’s CAMP.
1. Evidence of direct shipment authorizations extended to approved suppliers is required. If a replacement part is shipped under direct ship authorization, the Authorized
Release Certificate must indicate that the PAH has authorized direct shipment. This indication may be a supplemental “remark” entry on the Authorized Release Certificate indicating the authorization to the supplier for
direct shipment of replacement parts from the supplier’s location.
2. New parts that were received into inventory prior to October 1, 2016, must, at a minimum, have a document or statement (containing the same technical information as an FAA Form 8130-3) issued through an approved
design holder, the PAH, or supplier with direct ship authority. These parts in inventory, documented with the required information, will be grandfathered and remain suitable for installation into U.S. articles, provided the
U.S.-EU MAG, Section C: Appendix 1 March 19, 2021 page 127 certification/release date of these parts is prior to October 1, 2016.
f. For new components released by an EU-PAH, release must be on an EASA Form 1 as a new part.
g. Parts fabricated by an appropriately rated, EASA-approved AMO, in accordance with EASA Part-145.A.42 may be acceptable for installation.
h. Standard parts meeting the requirements of 14 CFR § 21.9(a)(3), (such as a nut or bolt, manufactured in compliance with a government or established industry specification) are not subject to the forgoing provisions, provided such parts are accompanied by a
conformity statement and are in a satisfactory condition for installation.
i. PMA parts may be accepted only as detailed the TIP associated with Annex 1 of the Agreement.
j. New components provided by a U.S. owner/operator (e.g., 14 CFR parts 91, 121, 125, 129, 135) shall have documentation acceptable under the FAA system (e.g., as described in the current version of FAA AC 20-62, Eligibility, Quality, and Identification of
Aeronautical Replacement Parts).
7.3.2 Used Components.
7.3.2.1 Used components/parts consumed in maintenance must be traceable to approved FAA-certificated persons authorized under 14 CFR § 43.7. The signature, certificate number, and type of certificate held by the person approving the work must be documented. The part must be in an
airworthy condition and eligible for installation. An authorized release document, as provided below, is acceptable to accompany the part.
a. An FAA Form 8130-3 issued as a maintenance release that accompanies a part from a 14 CFR part 145 repair station.
b. An EASA Form 1 issued as a dual maintenance release that accompanies a part from an EU-based 14 CFR part 145 AMO.
c. A 14 CFR § 43.9 maintenance record entry that accompanies a product or part from a person authorized under 14 CFR § 43.7.
7.3.2.2 Used components from an EASA-approved part 145 AMO not FAA-approved must not be used even if accompanied by an EASA Form-1.
U.S.-EU MAG, Section C: Appendix 1 March 19, 2021 page 128
7.3.2.3 Used components provided by a U.S. air carrier must have documentation in accordance with the U.S. air carrier’s or operator’s CAMP.
7.3.2.4 Acceptable components based on provisions of other bilateral agreements are not contained in this guidance. Please refer to the individual agreements or FAA AC 20-62.
[urlp=https://www.easa.europa.eu/en/downloads/120966/en]EASA Link MAG 8[/url]
I hope this shed some light on this.
miamiair (netAirspace FAA) 29 Sep 23, 17:58Post
From an article I just read:
The bottom line, at least so far: A small broker—which, like all parts distributors, has no mandatory certification or special license—devised a scheme to acquire old parts and pass them off as either new or reconditioned by forging key documents.
ShanwickOceanic (netAirspace FAA) 30 Sep 23, 16:24Post
miamiair wrote:no mandatory certification or special license
I wonder how long that will last...
JLAmber (netAirspace ATC & Founding Member) 03 Oct 23, 19:24Post
In the UK it should change by early 2024. Brokers supplying Airbus parts on the secondary market are already being told to get approvals along the lines of a third tier sub-contractor, which is only fair. If the guy who makes the stickers for lav doors needs an approval (and he does), anyone middle-manning potentially major structural components should be subject to the same conditions.
