DHL 752 Freighter Crash-Lands at SJO
Zak (netAirspace FAA) 07 Apr 22, 17:10Post
A DHL 757-200 (PCF), reg. HP-2010DAE, enroute SJO to GUA, stopped its climb shortly after takeoff, flew a holding pattern and then veered off the runway upon returning to SJO.
The hull broke into 2 pieces. No reports about injuries or casualties at the moment.
Video: https://twitter.com/CR_Aviation/status/ ... 7084728331
FR24 flight data: https://www.flightradar24.com/data/airc ... e#2b69a801
EDIT: another video, and a rather spectacular one: https://twitter.com/adsbcr/status/1512109586672762887
GQfluffy (Database Editor & Founding Member) 07 Apr 22, 19:02Post
Yup...goes to show you still can't drift the ass end of a 757. :))
Hopefully the crew is ok.
darrenvox 08 Apr 22, 23:02Post
ouch there hope no one was hurt
https://darrensfs9site.weebly.com
DXing 14 Apr 22, 01:36Post
MROC will close between the hours of midnight and 5am local Wednesday and Thursday to facilitate the removal of the DHL 757 hull from the field.
https://www.aviacionline.com/2022/04/costa-rica-san-jose-airport-will-close-to-allow-removal-of-dhl-boeing-757/
https://simpleflying.com/san-jose-airport-closure-dhl-wreck-recovery/
Maybe things went much more quickly than expected as I don't see any notam in the system regarding MROC being closed for Thursday early morning.
ANCFlyer (netAirspace ATC & Founding Member) 14 Apr 22, 10:44Post
I watched the video several times . . . . saw heavy braking action, but didn't see thrust reversers deployed . . . did I miss something?
miamiair (netAirspace FAA) 14 Apr 22, 11:46Post
ANCFlyer wrote:I watched the video several times . . . . saw heavy braking action, but didn't see thrust reversers deployed . . . did I miss something?
TRs are hydraulically actuated. They had hydraulic failure. The tires smoked, they do have an emergency brake. Unfortunately, there is no emergency steering.
miamiair (netAirspace FAA) 14 Apr 22, 11:53Post
Let me add a little correction, IIRC, you have a slight amount of control through the rudder pedals, but it is no more than ten degrees.
DXing 17 Apr 22, 11:53Post
Once below 80kts the rudder starts to lose its effectiveness. Loss of control in the video was definitely under 80kts. I wonder if the plane didn't start to drift and with no nosewheel steering the pilot tried to use differential braking? If so, the possibility exists that the hydraulic accumulator ran out of pressure on the left side and caused the unrecoverable slide to the right? Just my {twocents} .
